Symptoms
- The device fails to boot normally and drops into the Linux emergency console (“BusyBox / initramfs”).
- The keyboard is not recognized, either in the boot menu or in the emergency console.
- Pressing Esc right after power-on does not open the BIOS setup.
- The problem persists with several keyboards (wired and wireless with USB receiver) on every USB port.
- Fully unplugging the power and holding the power button to discharge residual power did not help.
Step 1: Reset the power state
- Unplug the power adapter and all external devices.
- Press and hold the power button for 30 seconds. Repeat this 3 times.
- Reconnect the power adapter and your keyboard/mouse, then check whether the keyboard is recognized.
Step 2: Reset the RTC (CMOS) battery
Only do this if you are comfortable opening the device.
- Fully power off and unplug the device.
- Open the case and remove the CR2032 RTC coin-cell battery from the motherboard.
- Wait 10 minutes, then reinstall the battery.
- Reconnect power, boot, and test the keyboard.
Step 3: Boot without the SSD
If the SSD holds company data or is covered by a confidentiality agreement, you do not need to send it back with the device.
- Remove the NVMe SSD and store it safely. See the disassembly video below.
- Power on the device without the SSD. It should enter the BIOS automatically.
- Test the keyboard on different USB ports to see whether it is recognized.
[Insert disassembly video here]
Still not working?
Please contact GMKtec Support with your order information and the results of the steps above, and we will arrange diagnosis and repair under warranty. If you send the unit in, you can use your own test drive if needed. Removing the SSD does not void the warranty.
