We’re excited to share an in-depth review of the GMKtec EVO-X5 Pro, published by Frandroid, one of France’s well-known technology media outlets.
Written by Ulrich Rozier and published on October 27, 2026, the review explores what makes the EVO-X5 Pro special, particularly its AMD Ryzen AI Max+ PRO 495 processor and massive 192GB unified memory.
What Makes the EVO-X5 Pro Stand Out?
The review puts the EVO-X5 Pro through extensive real-world testing, covering CPU and GPU performance, local AI inference, storage, thermals, power consumption, and more.
Here are some of the highlights:
192GB LPDDR5X Unified Memory: Up to 160GB can be allocated to the GPU, making it possible to load AI models that exceed the memory limits of conventional mini PCs.
Local AI Model Capability: Successfully runs Qwen3-235B-A22B in both Q4 (134GB) and Q5 (167GB) quantization.
Powerful Processing: AMD Ryzen AI Max+ PRO 495 with 16 Zen 5 cores and 32 threads.
Integrated Graphics: Radeon 8065S with 40 RDNA 3.5 Compute Units.
High-Speed Connectivity: Dual 10GbE Ethernet and USB4 v2 connectivity up to 80Gbps.
Quiet Cooling: Stable performance under sustained workloads, with relatively low noise levels.
A New Possibility for Local AI
One of the most interesting findings is that the EVO-X5 Pro’s biggest advantage isn’t a dramatic increase in raw computing performance over the Ryzen AI Max+ 395.
Instead, it’s the additional memory capacity.
With 192GB of unified memory, users can run significantly larger local AI models, work with longer context windows, and explore more demanding AI development workflows directly on their desktop.
The review also compares the EVO-X5 Pro with NVIDIA’s RTX Spark platform and Apple’s Mac Studio, offering an interesting perspective on the evolving local AI hardware landscape.
Read the Full Review
A big thank you to Ulrich Rozier and the Frandroid team for taking the time to thoroughly test the GMKtec EVO-X5 Pro!
Original review: [GMKtec EVO-X5 Pro – Full Review on Frandroid]
Original article and review by Ulrich Rozier, published on Frandroid on October 27, 2026.
What would you run on a 192GB unified-memory Mini PC?
A 235B local LLM, AI coding agents, large-scale model inference, or something completely different?
Share your thoughts and projects with the GMKtec community!
